Wheel Backspacing, Offset, and Tire Sizing. Updated 04/20/08
Discussion in 'Tune Discussion' started by RedGalant2k1, Dec 4, 2007.
  1. JDM FLOW
    Would Rota P45F's +35 work on our cars?
  2. RedGalant2k1
    Depends on the width of the wheel, but it would go on nicely to an unlowered Lancer for sure. Lowered Lancer is another story, and being that its at least 8" wide more than likely you may get some rubbing. That also depends on each vehicle, tire size, wheel width, etc etc...
    There are a lot of factors.
  3. JDM FLOW
    18x8 +35 or +45 offset ...
  4. WIREBLADE
    WIREBLADE Well-Known Member
    Guys I need some of your advice in what tire size should I go with 18x7.5 +45offset. Should I get 225/40/R18 or 235/40/R18 my ride is lowered with tein S-Tech Thanks!
  5. RedGalant2k1
    225/40-18s.
  6. RedGalant2k1
    Moved to Knowledge Base.
  7. jacob1bc
    jacob1bc Well-Known Member
    i thought this so helpful in any question about offset
  8. dcobeo7931
    dcobeo7931 Well-Known Member
    ok so while i have been gone i went and got my lancer lowered....with the tein s-tech springs....
    and then i swapped out wheels...at first it was to see what fit...but they looked so good i kept them on....
    i got galant ralliart wheels...235 45 18 with the 2.1/1.9 drop...its only about a finger of gap, if even that
  9. RedGalant2k1
    Nice, have you experienced any issues with that larger size?
  10. dcobeo7931
    surprisingly not many...the usual drive slow over speedbumps.....and a little rubbing when i turn from lock to lock....i've maybe lost an 1/8 of my turn radius, but i rarely turn that tight except when i need to get out the drive way lol........so all in all i think i made a great choice..gonn do the galant with the s tech springs and put 19's
  11. dogdog130
    dogdog130 Well-Known Member
    so question i have a es so i can fit all the ones in red on my rims
  12. RedGalant2k1
    Yes, minded the wheels are similar to the widths marked in red. What kind of wheels do you have? Size? Width? Offset?
  13. dogdog130
    see i got the stock 205/60/16 and i need new ones and there is a got that got 4 tires for 70$ and i need to know what all sizeing will fit on the es
  14. RedGalant2k1
    Need more information.
  15. WIREBLADE
    Is it possible that 19x8.5 +38 or +45 offset would fit in a Lancer GTS without rubbing issue?
  16. CRAZY-LEGS-20
    Im having the same problem...i got some 19" rims with a +35 offset...19x8 with offset of +35....the tires im thinking on are some hankook ventus v12....225/40 r19...are they going to rub if i drop the car in the front and rear?
  17. bakwoods
    bakwoods Guest
    Yup. There's a great site http://www.willtheyfit.com/, and you can use that to figure out how your stats compare to the OEM. You can plug in 225/45/18 18x8 for the stock size and then your 225/40/19 19x9 for the new tire. I looked over the diagram (not 100% accurate) but it does show major rub on the strut side. Even with that offset. In order to get that setup to work (which I know is possible if I've seen a Civic on 20's) you can roll and pull the fenders. A shop that does it without messing up the paint is def a good body shop. I'd shop around and ask.
    Personally though only reason I didn't go with 19's is because they are a little too big and harder to fit on the cars especially if you drop them. I'm going to get coils first, then drop the car, then make up my wheel/tire combo from there.
  18. bakwoods
    bakwoods Guest
    To anyone who's reading this and wants to know about sizing. Here's the deal.
    1. You can make ANY WHEEL COMBINATION FIT! You just have to be prepared to dish out money to make it work. The bigger the wheel, the more it'll cost to fit under there.
    2. Those of you that don't know what the numbers mean: 205/40/18
    205 is the width from one end to the other
    40 is aspect ration aka 40% of 205
    18 is the size of the tire.
    3. Offset is VERY IMPORTANT when selecting your rims. Higher the offset, the more tucked in the wheel will be. The lower the offset, the further out it will stick. IE: You can run 2 sets of 225/45/18s one is 18x8 with a +45 offset and one with a +35 offset. The one with the lower offset will stick out more from your car. Compare your offset of the new wheels to your OEM.
    4. What will fit? 18x8 and 18x8.5? Simple. Wider the wheel aka 8.5" vs 8" is just going to accomodate a wider wheel. For our 8G Lancers, 8" will be a safe bet without rolling the fenders. Any larger and you'll start rolling fenders, pulling fenders, cutting liners material, etc.
    If you've ever looked up the term "hellaflush" that's exactly what these guys do. Wide wheels (8.5" minimum) with really low offsets (+25 and such) and stretch their tires. Granted if you don't mind giving up cushioning and messing up your rims for the looks. Oh and grinding up EVERYTHING under the car when you slam it...go for it!
    If you find this information helpful, please sticky.
  19. Jamesprigh
    Jamesprigh Well-Known Member
    http://www.robertoperera.com/prik/
    https://book.weddingsja.com/plok/
    vevguliinsulancea324
    ms windows 7 service pack 1 download free , http://newsfrom66conspunabely.blogspot.com/2022/01/dj-mixing-software-for-pc-full-version.html , ytd latest version download for windows 8.1 free , downtown run pc game download free , , download antivirus for windows 7 for 90 days free ,
    download scrabble game for windows 10 free , http://newsfromciagnosidfuya.blogspot.com/2022/01/iso-windows-10-1809-pro-free.html , clue board game for pc download free , counter strike game download for pc full version windows 8 free , https://sites.google.com/view/gw54lskftkbd10vw/n92sgkhg8wrfj40 , pokemon trading card game play it download pc free ,
    windows 8.1 bootable usb maker software download free , https://sites.google.com/view/2bc6c2xb96h1kk155lo2vqzb0/nw9qgaztml56e0uvmllk3liz , download youtube downloader for pc windows 8.1 free , download kmp media player for windows 10 free , http://newsfrom9specpiligtov6.blogspot.com/2022/01/adhan-software-for-windows-7-download.html , download driver printer canon ip1980 untuk windows 7 free ,
    download wwe raw 2013 for pc free , , video editor software download for windows 7 free , download sandisk secure access win free , http://newsfrom6placexlafuau.blogspot.com/2022/01/python27-environment-variables-windows.html , gta sa download for pc windows 7 free ,
    plants vs zombies 2013 final full pc version download free , https://sites.google.com/view/t5kjm1hfczr1hmkej/1nj7n9qmjlb6y885s4eetpw8fe , windows 8 product key viewer download free , tom clancy's hawx 2 pc crack download free , , pc game dr driving download free ,
    subway surfers pc download and gameplay with keyboard and joystick free , http://newsfromlitcevegem7.blogspot.com/2022/01/perbedaan-sony-vegas-pro-11-dan-13-free.html , full hd mp4 video songs download for pc free , 64 in 1 games download for pc free , , download pc aircraft games free ,
    crack win 7 starter download free
    microsoft word 2010 gratis downloaden voor windows 7 free
    windows 8.1 update power button download free
    windows live messenger 2012 download gratis portugues free
    http://firstaboutdowbload.org/map10.php
    https://how-tonow.fun/map.php
    marketplace download windows free
    epson easy photo print download windows 7 free
    jogo 007 nightfire pc download free
    download kms activator windows server 2008 free
    pou download for pc windows 7 free
    final fantasy ix pc steam download free
    e return tool version 5.0 software download windows 7 free
    english malayalam dictionary download for windows 10 free
    battle realms winter of the wolf full download free
    rayman the great escape download pc free
    download abbyy finereader for windows 8 free
    https://bit.ly/3tsn3sL , download jeux de course pour pc free , https://bit.ly/3GQntwH , pc game cricket 2002 download free ,https://bit.ly/3Fn0SGO , download bible pc software free ,
    https://bit.ly/3IeWN9x , red crucible download pc free , https://bit.ly/3nvyQCS , tekken tag 1 download for pc free ,https://bit.ly/33FqHol , winning eleven 2012 download for ipad free ,
    https://bit.ly/3AjJr8T , download sports games for pc compressed free , https://bit.ly/3qtU4mv , download angry birds rio full game for pc free ,https://bit.ly/3fnFOoP , uppcs 2015 pre exam paper download free ,
    https://bit.ly/3tqzHs1 , winterbells android download free , https://bit.ly/3GFs2dv , samsung galaxy gt-s6312 pc suite download free ,https://bit.ly/33hvVGU , download lenovo energy management software windows 8 free ,
    https://bit.ly/3riiD4Q , mysql for windows download free , https://bit.ly/3qwPeog , pc games hardware ebook download free ,https://bit.ly/3qmdklE , windows 8 download remote desktop client free ,
    my little pony friendship is magic pc games download free
    download game pc delta force 4 black hawk down free
    cmi8738 c3dx pci audio device driver download for xp free
    animated waterfall wallpapers download for windows 7 free
    download minecraft pc terbaru 1.9 free
    windows 98 maze screensaver download free
    https://aboutthreefiles.org/map91.php
    http://bestfreefiles.org/map186.php
    alcohol 120 download windows 7 free
    windows 7 games themes download free
    download folder lock for pc window 8.1 free
    windows 8 pro build 9200 activator 64 bit download free
    http://vschitre.org/kvit
    https://estibela.cl/emon
    http://1799.downloadfirstyou.com/
    es file explorer download for pc free
    http://bestfreefiles.org/map56.php
  20. Jamesprigh
    https://www.rudraequipment.in/hapy
    https://opcina-policnik.hr/kult
    equalizer music player download for pc free , http://newsfrom92cinetcidead.blogspot.com/2022/01/download-skate-2-pc-demo-freeskate-2.html , equalizer windows 8 download chip free , nascar racing 2003 pc game download free , http://newsfrom880inexpronbah1.blogspot.com/2022/01/microsoft-office-2016-word-download.html , download skype for desktop windows 7 free ,
    avg antivirus download windows 8.1 free , http://newsfrom8ciacosume9m.blogspot.com/2022/01/windows-7-usbdvd-download-iso-file-free.html , download game kartu spider solitaire windows 7 free , razer megalodon driver download windows 8 free , http://newsfrom4inesorzodw.blogspot.com/2022/01/windows-10-home-to-pro-key-not-working.html , win magazine 198 download free ,
    fantasia painter download for windows 7 free , , download driver sony vaio s series vpcs125fg free , motorstorm game download for pc free , http://newsfrom3cabihaeba5j.blogspot.com/2022/01/story-maker-download-for-windows-7.html , download game pc gta san andreas single link free ,
    windows 7 folder lock software download free , http://newsfromscelplicutkeng.blogspot.com/2022/01/adobe-flash-professional-cc-portable-32.html , cissie redgwick - gimme that swing download free , spiderman 1 pc game download free , http://newsfrom5gnosocidhocl.blogspot.com/2022/01/wanted-weapons-of-fate-download-full.html , dritek launch manager acer windows 7 download free ,
    tamil movies download 2013 for pc free , https://sites.google.com/view/g7m6hg1vbbscmesujgwcp9glp2/440l4ft15jh7lnr , five nights at freddy's 4 download pc free , pc cricket game download now free , http://newsfrom137exumanfuku.blogspot.com/2022/01/download-full-version-windows-7-themes.html , samsung galaxy y duos usb drivers for windows 7 download free ,
    psp vita emulator download pc free , https://sites.google.com/view/l48d3pqzbs/2ggxnjn8kleka160eosbr5g0c , toshiba bluetooth peripheral device driver for windows 7 download free , nvidia geforce download windows 7 64 bit free , http://newsfrom230tafanconchi0v.blogspot.com/2022/01/winamp-for-android-full-version.html , eset antivirus download for pc windows 7 free ,
    pc fighting games download free
    zune software for nokia lumia 800 download for pc free
    big win racing hack download no survey free
    p8 v25 file (rar and exe) download free
    https://aboutthreefiles.org/map72.php
    http://bestfreefiles.org/map64.php
    download gta 3 on pc free
    photo converter software download for windows 10 free
    download wrestling games for pc 2013 free
    latest bollywood movies download in hd for pc free
    download windows 10 enterprise 10586 free
    windows media player 10 download for windows 7 32bit free
    nfs underground 2 exe file download free
    download bitlocker windows 7 64 bit free
    download driver printer canon lbp 1120 for win7 64 bit free
    3d screensaver maker software download for windows 7 free
    download windows surface scanner 2.0 free
    https://bit.ly/3qMsIbd , snes emulator download pc free , https://bit.ly/3fvIj8w , pro evolution soccer 2012 download pc utorrent free ,https://bit.ly/3AiXgo5 , download 3d background for pc free ,
    https://bit.ly/3InZGVh , download gta san andreas pc windows 7 baixaki free , https://bit.ly/3nsScZe , download driver motherboard msi k9vgm-v free ,https://bit.ly/3FuGvao , google play download error rpc s-7 aec-7 free ,
    https://bit.ly/3nL0uvx , best video download manager for windows 7 free , https://bit.ly/3rA4j81 , hardware changes might not have been detected windows 7 download free ,https://bit.ly/3Ftnnda , adobe reader 10 download for windows 2003 server free ,
    https://bit.ly/33wW7xx , openssh for windows server 2008 r2 download free , https://bit.ly/3KcWqxI , candy crush saga download for pc free ,https://bit.ly/3tppxbs , age of empires 3 download completo em portugues gratis para pc free ,
    https://bit.ly/33yE2ic , download appid.patch.exe free , https://bit.ly/3zVw928 , download o clube das winx 1 temporada free ,https://bit.ly/34UxU4v , cross dj for windows download free ,
    download game winning eleven 10 full untuk pc free
    adobe illustrator cs6 download windows 10 free
    3dmark windows 7 download free
    download game street fighter untuk pc free
    download microsoft word 2007 for windows 8.1 64 bit free
    fujitsu lh531 drivers download for windows 8 free
    http://bestfreefiles.org/map10.php
    http://bestfreefiles.org/map36.php
    hp laserjet 6p driver download windows 10 free
    hotel management games for pc download free
    pc virtual dj mixer download free
    google apps download for windows 8.1 free
    http://box2306.temp.domains/~tillkrue/_wp/pirs
    https://limousineprestigetravel.com/toch
    http://1268.allorgdownload.org/
    tomb raider underworld pc game trainer download free
    http://bestfreefiles.org/map156.php
