would they ? http://www.tirerack.com/wheels/MiniWhee ... ue&sw=1280 and would it look good on my lancer 09 ? it`s black :X ... i`m just asking cuz i don`t know the stock size of the tires.
if you put in your car for the filter thing on tirerack, anything that comes up will fit. After looking at your link, I'm assuming you have an ES. That being said, the tire/rim size are... 16x6.5 5x114.3 lug pattern +46 offset Tires are P205/60R16 91H Since it seems you're not too educated about wheels.. i'll give you a quick lesson. if you know.. well.. then you should have already known the answer to your question First the rims... 16x6.5 means 16 inch diameter by 6.5 inch width 5x114.3 lug pattern means there are 5 lug nuts to bolt the wheel on and each spot is 114.3mm apart +46 offset means the distance the mounting part of the wheel is from the centre. Tires... P = passenger (type of vehicle the tire is for) 205 = width 60 = side wall height in % of width. ie. the sidewall height is 60% of 205. R = construction of the tire 16 = diameter of the tire 91 = load rating. how much weight the tires can hold H = speed rating. how fast you can go without worry of blowing the tires.
lol i guess i forgot that part. haha you're only icnreasing width by 0.5 inches.... it should still fit.. but it seems that you want the tire width to be 1inch bigger than the rim width... (going off stock numbers) so this rim might be a bit of a stretch.
