***UPDATE***UPS was good to me today
Discussion in '8G Lancer - Suspension' started by blacksheep818, Jan 29, 2008.
  1. blacksheep818
    if we're going to do a canyon run we need to have room to actually ''test'' our suspension out
  2. pimpinfern
    pimpinfern Well-Known Member
    thank you, looks like it dropped a small bit in the front
    yeah boyeee and remove the fuse for the abs!!!!!
  4. GTS-SB
    GTS-SB Well-Known Member
    looks good Blacksheep!!! im down for another canyon run!
  5. playa213xx
    playa213xx Well-Known Member
    how did you do this yourself?? i'm pretty sure you need a spring compressor to do that...most of the time your general service repair shops will have them but if you did this...in say....your garage....please explain....
  6. Guest
    looks good brudda
  7. kinkbmxrydr
    i actually did it without a spring compressor
    "U" got very lucky.
  9. tatsujo
    Nice, looks good man. Any clearance problems so far with dips, driveways, etc?
    Kink, you installed yours yourself?
  10. blacksheep818
    thanks.....no problem clearing anything i can go straight up dips and driveways
  11. kinkbmxrydr
    yea if u need it done then let me know
  12. playa213xx
    how did you do it without a compressor? they don't look like their loaded lol
  13. RALLIART
    yeah strange about the drop in the front... mine dropped al lot more in the front when me and my buddy did them, and it was noticeable drop didnt even have to settle....
  14. blacksheep818
    which ones do you have ? the V1 or V2
  15. Guest
    no he went to my buddies place.
    So let me know now that I have the shop going.
  16. lancered
    lancered Well-Known Member
    i didnt use a compressor either.the springs are pretty stiff but,all i can explain it best is that we sat the shock on the ground (vertically) put the spring on the shock.made sure it sat right,put the top plate on top of the spring and made sure that it was sitting right,then my friend held the shock and spring while I pushed down hard with my hulk arms :lol: .if it was straight then he would hurry and screw the nut on so i dont have to hold it down any longer,i have to say they are some pretty stiff springs but we got them on.only took us about 30-40 minutes.we was working with a flashlight too just to be abe to see what we was doing,lol.
  17. bras_33
    /\ you guys must like danger and not using a spring compressor
    pwnd
  18. lancered
    /\i know were bad :twisted:
  19. topher
    topher Well-Known Member
    im going to get those springs as well!
    the drop looks good not to extreme!
