Looking for new wheels. Is the tire sensor error a constant beep? Or is it something that I could live with as it would only appear on the info panel. No problems leaving it off really is there?
i heard theres a beep for like the first mintue when u start it up, after its just going to be on the panel, then if you open your door the beeping noise will coem back on
Awesome, I guess I can live with that. Do you know if it would be possible to just switch tires if I bought a set of 18" rims?
If you do not like the Panel light, you can pull the fuse for it in the main in cabin fuse box and it should go out, unless Mitsu made the whole dash one fuse which would suck... Bill
Hi! If I'm gonna buy the Tire sensor do I also need to buy the nut for it? or does it comes with it already. Thanks!
i got a ES i change to 18's and the the rim with tires (low pro) are stocks were not stock. i asked the tire shop to change the sensor from the old ones to the new ones. they did charging an extra 20 bucks. i havent seen it go off yet
