Intake Help Please
Discussion in '8G Lancer - Performance' started by Superman327, Jun 23, 2012.
  1. Superman327
    Superman327 Member
    I have a 2010 Lancer ES and am looking to put in a short ram intake. I would like to get a Takeda SRI but don't really know what the best option is. Help please??
    Any other opinions for more horses would be welcome too! haha
  2. blueking_4
    blueking_4 Well-Known Member
    I can honestly tell you that I have the Takeda SRI for my GTS, which has the 2.4L engine, whereas your ES has the 2.0L. I'm sure they make it for your ride, and I'd highly recommend it. I've had mine in the car for a little over a year, and from day 1 ive noticed some difference.
  3. Superman327
    Superman327 Member
    Very nice man, I am sure it sounds sick. And the only Takeda I can find that might fit my car, is .. http://www.andysautosport.com/mitsu...performance/intakes/short_ram_intakes/takeda/ and it says it fits the 08 and 09 model. Would this fit my car too you think? Also, what are your views on HPS ? http://www.ebay.com/itm/320921147041?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 Or perhaps this ingen http://www.ebay.com/itm/320930318295?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 And thank you very much for replying I appreciate it.
  4. Superman327
    Superman327 Member
    I ended up getting a used Injen SRI. I installed it yesterday and the service engine light came on. Is there a way to fix this? Possibly a leak somewhere?
  5. Superman327
    Superman327 Member
    And I did reply a few days ago but apparently it never went through...but I picked up the injen intake and injen axel back exhaust for $350. They look almost brand new once I cleaned them up.
  6. Eshort
    Eshort Member
    That cel light happens with new intakes, the maf is reading more air than usual it should go away after a few days but if not I wouldn't worry about it, I have the takeda 2.0 and lover it and also had the rrm v2 sri and I loved them both. But that cel light is common and should go away soon
    Sent from your moms phone using Tapatalk
  7. blueking_4
    hmmm...i've never had the CEL come on with mine...i honestly don't know what to say.
  8. evilstig4b1
    evilstig4b1 Well-Known Member
  9. Superman327
    Superman327 Member
    once I go through to check it and tighten, will the light reset itself?
  10. Eshort
    Eshort Member
    No it could take a few days or you can take the ground off the battery
  11. sk13322
    sk13322 Well-Known Member
    I installed the takeda short ram and never got a light on a 2011 sportback. Check to make sure everything is tight and clean the maf sensor with maf sensor cleaner just becarefull and make sure it sits in the intake right and tight but dont strip the bolts.
  12. SpartanSMH
    SpartanSMH Member
    Rrm provides a new o-ring for your sensor too. Maybe double check you're not getting a leak from the stock o-ring?
    Sent from my iPhone using Tapatalk
