engine paint?
Discussion in '8G Lancer - Customization' started by rotorglowgts, Oct 6, 2013.
  1. rotorglowgts
    rotorglowgts New Member
    hi id like to paint the plastic engine cover red or orange...what type of paint would work? engine enamel...plastidip? thanks
  2. lancer2quick
    Any paint will work just fine...as long as you clean it VERY well and prep. If you use just the run-of-the-mill rattle can, you will have to scuff it up a bit and prime it first. I have used the Krylon for plastic and vinyl without priming...always turned out well. You can use the engine enamel, but there is no need for high temp paints on the plastics...nowhere near hot enough.
  3. OptimaLancer
    OptimaLancer Member
    This^^^ , Krylon Fusion is great stuff and Lowe's also sells a Rustoleum for plastics that I've used. Post up some pics when you get it painted!
