DIY Rear window vents...
Discussion in 'DIY' started by lancer2quick, Jul 4, 2010.
  1. lancer2quick
    Ok, I have wanted the rear window vents from Rexpeed for quite a while new....just couldn't find myself throwing out 200+ bucks for a set. I had some Ideas on how to make them, but never started until now. Here's the how-to that I have so far...I 'm just now finished with the first half of the process, but I will post the rest when I finish.....Give me a few minutes to upload pics........
  2. lancer2quick
    Step 1 Tools Needed:
    DOW styrofoam insulation board
    Tape measure
    Marker or pen
    Exacto or loose razor blade
    First go to Lowe's, Home Depot, Etc. and pick up a sheet of the DOW blue styrofoam insulation board. Its sold in a 4x9 sheet for around 7 bucks (the extra makes a great pad for lying on the ground while working). I had some lying around the house from other projects, found the best piece and went to work.
    when you're ready to start marking and cutting, you can use the board itself or a piece of cardboard to make the template. Make sure you pull the layer of plastic from both sides of the styro.....a lot easier. I know the length needs to be roughly 25 inches for the 7Gen rear windows....height is purely up to you. Once you have the basic shape, put it into position and check the fitment. I went through 3 before I got a good fitment...lol.
    Also check how far it extends from the window...you only want enough to be flush with the door trim....
    Next is another variable. Decide what size and how many holes you want in the vent. Whatever you choose, keep an even space from the top, bottom, and the other holes to help make sure it stays structurally strong. I went with 5 holes...don't exactly know the diameter...I just traced around an old can I had lying around.
    When cutting the holes...TAKE YOUR TIME!! Try to keep the board as flat as possible, to avoid breaking it. I had 3 holes done, and went too quick on the fourth...and had to start all over. After you have the holes done, check the fitment and looks of the piece. If you don't like it, you can start over...adding more holes or taking some out.
    That's as far as I have gotten as of now. The next step is going to be final shaping and fiberglassing over them. When I get to that stuff, I'll keep this going for you guys....
  3. Jogenmaru
    Any updates yet? How much has this cost you so far as to buying a set from a reputable dealer??
  4. 1slowlance
    That's really cool. Looks exactly like the ones from RRM. I thought about getting them for a while, but changed my mind.
  5. lancer2quick
    I haven't had time to finish them...but so far I only have about 30 bucks in them.
    7.00 for the foam board
    15.00 for the fiberglass resin
    10.00 for the fiberglass fabric
    All I have left to do is fiberglass, sand, then paint them....The wife is off this weekend, so I might try to finish them then...
  6. Hello there. I know this post is a little old, but it helped me to do mine.
    Here i post some photos of my progress.
    Materials I used: Ikea chopping board for the mold
    Plexiglass for the final piece
    Black vinyl to wrap the piece
    Comments will be appreciated! :)
  7. 1slowlance
    Sick. Forgot all about this. Wonder if Jamie ever finished his...
  8. lancer2quick
    Nice job Molina. And no, I haven't finished these. I've got them shaped and ready for fiberglass, but haven't taken the time to finish....but it's springtime now and could use them, so I might pull them out and finish.
  9. Jogenmaru
    Quick question. Would a cookie cutter work better than an exacto knife? for the more perfect circle and all that good jazz
  10. lancer2quick
    I don't see why not.
  11. evilstig4b1
    evilstig4b1 Well-Known Member
    I like the rally look of it, ect. but what is the purpose, goal and so forth of the "rear window vents"?
  12. evilstig4b1
    +1 "cookie cutter". Niiice LOL
  13. lancer2quick
    To let air circulate through the cabin without fully rolling the windows down. They will pull fresh air through the cowl under the windshield and out of the dash vents.
  14. 03 ES GUY
    03 ES GUY Well-Known Member
    I never thought of those vents being much technical use except just for looks. Now that I see the real use, I might just make myself some. I still have fiberglass and resin left over from a failed attempt at make sub boxes when I had my grand am
  15. roblaza
    roblaza Well-Known Member
    hrrrmmm... looks interesting. I'd like to see the finished product
  16. 03 ES GUY
    Regardless, I'll do it. My son hates the windows down. Thus the vents so air gets sucked in.
  17. Thank you.
    Im working on the plexiglass right now, soon, ill upload more pictures
  18. blueking_4
    blueking_4 Well-Known Member
    L2Q's DIY娪
    Yeah, I registered and trademarked it for you. Lol!
  19. 03 ES GUY
    Coughbrownnosercough. Lmao
  20. 1slowlance
    ^ Exactly what I was thinking.
