Hello my dear colleagues. As I found myself always looking for answers on this community for my problems and questions about which is the best mod for my car, what the result for that other people got for the same mod that I am willing to make, results made possible only by taking chances and spending time and money of their own pockets, it thing it is time to share back my experience with you guys. My bad experience, so you could have a chance not to go and make the same mistakes as I did buying BAD QUALITY products. My car is an Mit EVO9 (other cars that I own : STI03, Civic TypeR, BMW E30 M3, Celica CS, Audi S3 1.8T, Dacia Logan CUP-race car) and some of my mods are : FP Green turbo, Deatschwerks injectors 750, ARC intake box and titanium intake pipe, HKS cams, HKS coilovers, Ralliart 18†wheels, and some other small parts. Recently I wanted to improve the braking on my car and beside AP Racing 6pot 362mm kit (which I have on my STI for 3 years-12000km and I love them) and BREMBO GT 6pot 355mm kit I was also considering the Taiwan company called D2 which makes a massive 380mm 8 piston kit for the EVO. 2 things made me to make the wrong decision, the bigger diameter of the rotors, 380mm versus second best AP Racing 362mm, and the cheaper price compared to the AP and the Brembo kits, so I got the D2 brake kit. – STUPID MOVE I know that this topic is not about me, but a short introduction will show people that I really don’t thing that the problems with the brakes comes from bad installing or abuse : I run in my country a tuning company called Superformance, dealer of SKN Tuning Gmbh since 2007, with some rally and hill climb activity in the last years : tech support in 2009 for hill climb national champion open category in an EVO6, and my personal race history running with 1.6 Dacia Logan : 2008 FIA GT Logan Cup first race winner and after disqualified due to engine modifications, second race second place, 2009 hill climb champion at 1.6 category . My “raceâ€car : http://bloganul.blogspot.com/2010/11/loganul-skn-lui-andrei-tentean-de.html About the FIA GT event: http://prorally.ro/net/index.php?option=com_content&task=view&id=2964&Itemid=31 After installing the D2 380mm front brake kit I have made the brake in myself in a period of 450-500 km. After the brake in was over I started to use the brakes with moderate to full pedal pressure in different conditions to see what I have paid for, first results where not impressive , not bad but somehow different than what I was expecting . Brake pedal travel was bigger/longer than before and with a somehow unnatural behavior, first part of pedal push was return less braking than expected and the next part was locking the tires pretty easy. I suppose this is normal, the pedal travel should be longer because of the increased fluid than goes in the bigger than stock caliper and tires look is due to the excessive 380mm size ! – So first lesson : for the street using normal street tires you do not need 380mm discs to stop an EVO. The biggest problem came in the next 1500 km (all on the street, should have happened earlier on a track day or weekend), shacking under breaking become more and more obvious to a point the is nor pleasant or safe to drive the car anymore and stopping at a stop light the car will stop itself after releasing the brake pedal at 1 or 2 km/h and this means only one thing : pads are still touching(or even pushing) against the disc even when brake pressure is not applied !! After checking the wheel and tire balancing TWICE (and i do have the receipts to prove it) which was perfect exactly as I imagined because I run on Ralliart RAYS forged 18â€wheels and I always look after them, I put the car in the garage and make the next measurements which I also filmed to send to D2 but for no good because the answer was fast and clear – it is my fault, no warranty on brake discs. I tried to explain that heat damage to the discs came from heat build up during roll on from the faulty calipers which do not release the pads from touching the disc but the answer was still the same – no warranty for the brake discs !!! STUPID ME FOR BUYING D2 !! Same tests for both sides, left and right. You can see in the movies that the calipers are expanding under pedal pressure, this is bad manly for the performance orientated customer how will want some feedback from the brake pedal ! Pressure is wasted in the bad design and probably bad material caliper instead of going to the pistons and so on to the pads ! LEFT D2 caliper expanding under pressure http://www.youtube.com/watch?v=qEc29-ziWp8 RIGHT D2 caliper expanding under pressure http://www.youtube.com/watch?v=59Duap_A4iY Here you can see that using a dynamometric wrench we could approximate the effort needed to turn ONLY the disc – 30 Nm to a side and 45 Nm to the other !!! This is EXTREME ! This D2 people are wasting our hard earned horsepower !! LEFT D2 rotor 45Nm to rotate http://www.youtube.com/watch?v=FzVtv6CeVx8 RIGHT D2 rotor 30Nm to rotate http://www.youtube.com/watch?v=o_5sjPRCrZk And here you can see and imagine the shacking under braking !! discs are fucked up in less than 2000km, that is less than 1250 miles !! LEFT D2 rotor moving left and right http://www.youtube.com/watch?v=6c2BEJ7sPOU RIGHT D2 rotor moving left and right http://www.youtube.com/watch?v=7dglzqIseEE LEFT D2 rotor moving up and down http://www.youtube.com/watch?v=32Dybh2NyCA RIGHT D2 rotor moving up and down http://www.youtube.com/watch?v=JUbCSs9gHHY So maybe I am unfortunate, or maybe I really do not know how to brake or use a set of brakes, or even both, but I will not come close to the D2 ever again. Anybody can make mistakes but not to take responsibility for your product is not Ok. Hope this helps.
Welcome to LT. I'm not the greatest mechanic in the world, but I may be able to help. Since you are into racing, I'm going to assume that you have checked every brake line for small cracks and have checked all the connections for leaks. If you are using the OEM master cylinder, the size (bore) may provide the initial clamp force but releases because of the total capacity may not be enough to maintain consistent clamp force. If you are using an aftermarket performance master cylinder, it may be an issue with the o-rings...causing an internal leak. Since master cylinders are sealed, the fluid wouldn't leak out until the main seal fails. If this happens, there will be a pop and you will lose all braking force. Like I said, you have probably thought of this already, but that's what I know...
no, I didn't check that until now. Thank you for the suggestion. It seems ok, it is the oem brake cylinder.
https://59.atsluvefiles.in.net/ https://905.atsluvefiles.fr/ windows 10 enterprise and pro difference free download https://452.xbestfiles.pro/ https://254.xbestfiles.pro/ http://1805.downloadfirstyou.com/ http://748.downloadfirstyou.com/ windows 10 blue screen troubleshooter free download , update microsoft outlook 2016 mac free download , bluetooth windows 7 enterprise free download , microsoft office 2010 home and student download free download , filemaker pro advanced 12 installer free download , adobe premiere pro cc free download reddit free download , vmware workstation 14 license key crack free download , windows 10 x64 product key free download , https://aboutthreefiles.org/map73.php https://foirstdownload.org/map20.php microsoft office 2013 and 2016 difference free download , affinity designer grid lines free download , x86 32 bit windows 7 free download free download , sony vegas pro 13.0 32 bit download free download , windows 7 key genuine free download free download , autodesk autocad lt 2017 - english free download , windows server 2016 datacenter hyper-v free download , lost password windows xp professional free download , coreldraw graphics suite 2017 kurulum free download , windows 7 bootcamp gpt error free download , windows 7 repair tool usb boot free download , corel ventura 10 for windows 7 free download free download , https://bit.ly/3J1AgxW https://bit.ly/3GWvL5X https://bit.ly/32odHmA https://bit.ly/3AlEPiJ https://bit.ly/3H5GQSu , https://bit.ly/3p6cXeu , google chrome windows xp professional free download free download , https://bit.ly/324n5fc , windows 7 professional iso 32 bit with product key free download free download , https://bit.ly/3E2douw , download windows 10 1803 free download , https://sites.google.com/view/emztzt7o7rbt2q1/home , microsoft sql server 2014 business intelligence free download , https://bit.ly/3F9MfHf , microsoft visual studio 2015 free download for windows 8.1 64 bit free download , https://bit.ly/3Feabt4 , avid media composer 8.3 mac crack free download , https://aboutthreefiles.org/map61.php http://allthewaydownload.com/map13.php https://bit.ly/3ebeBoE , affinity designer templates free free download , https://bit.ly/3Fdid5w , microsoft office 2013 crack download windows 7 free download , https://bit.ly/3p6kbPz , ableton live 9 suite high sierra free download , https://bit.ly/3GUvtNr , windows 7 loader build 7601 free download free download , https://bit.ly/3GYXvaD , windows 10 pc won't boot into safe mode free download , https://bit.ly/3EaxjYl , adobe premiere elements 12 update free download , https://bit.ly/3GXdEwJ , java windows 8.1 pro 64 bit free download , https://bit.ly/3mfPp56 , microsoft office student 2010 download free download , https://bit.ly/3F702OW , windows 10 home single language factory reset free download , affinity designer ipad animation free download how to adjust brightness in adobe premiere pro cc 2015 free download windows server 2003 r2 enterprise 32 bit iso free download free download windows 7 ultimate 64 bit iso product key free download microsoft office outlook 2007 update free download http://bestfreefiles.org/map207.php http://bestfreefiles.org/map275.php windows server 2008 r2 sp1 standard 64-bit free download c for windows xp download free , adobe premiere pro cc 2016 download free free download , snagit 11 where are images stored free download , adobe audition 3 software free download free download , sketchup pro 2016 gratuit free download , microsoft project training 2013 free download , will windows 8.1 drivers work on windows 10 free download , adobe captivate 7 one2up free download , windows movie maker software for windows 10 free download free download , windows 7 enterprise password hack free download , chew wga free download for windows 7 free , windows 10 keeps rebooting on install free download , windows xp service pack 2 professional iso free download , autodesk revit mep 2016 crack free download , windows server 2008 r2 enterprise edition end of life free download , java 8.1 free download for windows 10 free download , windows xp professional key generator online free download , download microsoft office word 2016 for pc free free download , windows 10 switch desktop gesture free download , download microsoft excel 2016 for pc free download , https://bit.ly/35f60QR https://sites.google.com/view/3ev06qy83b2dit659n/l0cifjxwro7my9wlnfqo6ift https://bit.ly/3E7DSuB https://bit.ly/3fPH7xa https://bit.ly/3Jd3zOi , https://bit.ly/3GURcEC , download microsoft office 2013 free 32 bit free download , https://bit.ly/3sjqiSA , vmware workstation 10 64 bit free download , https://bit.ly/3pbcisa , vmware fusion pro 7 download free download , http://yourfreefiles.org/map25.php https://aboutthreefiles.org/map35.php https://bit.ly/3ecUiXX , coreldraw technical suite x6 free download , https://bit.ly/3Fa9Rf5 , microsoft office 2013 full version free download for windows 10 free download , https://sites.google.com/view/ceslmhpmiiw85h4yu9zym0y86d/home , windows 7 usb dvd download tool free download , https://bit.ly/3F73lFQ , windows 7 professional graphics driver free download free download , , adobe illustrator cc 2014 free download full version free download , https://bit.ly/3p8tlen , windows 7 home premium system language change free download , https://bit.ly/3FnpWxS , windows 10 dark theme file explorer not working free download , https://bit.ly/3G1KjQO , windows 7 professional crack 64 bit download free download , https://bit.ly/3shvKW9 , microsoft visio professional 2013 product key 64 bit free download , https://bit.ly/3pjcp5f , price of microsoft office 2013 in india free download , https://bit.ly/31bW3lA , adobe dreamweaver cc 2015 32 bit free download , https://bit.ly/3yG5g1y , adobe audition 3 buy free download ,
