Car PC
Discussion in 'Audio, Security and Electronics' started by blackeyed, Jun 15, 2010.
  1. blackeyed
    blackeyed Well-Known Member
  2. 1slowlance
    I think someone on here is doing something like that. I think Jogenmaru is. Not really sure, but I remember him posting about doing it and all the pieces he was going to use. Say something about this Jogen.
  3. Jogenmaru
    I did say something on my ipod but my post was deleted. Like it never showed up in the first place. Oh well. Was most likely my fault. And it was shieldwolf. Not me. I estimate it would cost around $1200 to do this with a decent computer and not a gaming computer. But Shieldwolf was looking into installing a touch screen on his 7g. I think this mod is more or less for the newer lancers since they have a double din radio. If I had the space to do something like this I would but we are only single din and it would require us 7g lancers to remove the a/c controls and whatnot to do it. Or put in in the passenger side where the glove box is. Thanks for putting me on the spot. It brought about an idea. Ima have to measure that up.
    But I think it would require a decent computer. A touch screen monitor (obviously). a long cable from pc to monitor. An external battery and something to convert the power source to hook up the computer. It's an interesting idea. But I travel and I don't have the room in the trunk to do that. Although I could try it. I have a pc right now and i could do this but I am half way to my turbo and I am finally moving out with my gf on January 1st. So I want to do the turbo first and then start with the pc part. I can also use it as a way to datalog and manage. +3
  4. Jogenmaru
    List of what you would need. I don't think this would be a complete list. I haven't even bothered trying this yet due to the radio restriction.
    A touch screen monitor with dvi or hdmi input or both, that would fit your double din. (its easier to get these cords long than trying to find a standard vga cable really long)
    A computer chasis that you can put in your trunk and install it with carpet to hide it and look good. Thats really going to be the hard part.
    A spare battery.
    The spare cigarette lighter such as the one currently installed in your car.
    A fuse for this cigarette lighter so you wont get a short and overload your computer.
    A cigarette lighter to plug converter. I don't know what these are called. The converter that lets you plug your TV into your car and power on. That thing.
    Something to mount the battery onto so it won't go flopping around in the trunk.
    I would choose liquid cooling instead of air cooling like the guy in the video did. It would get pretty hot in the trunk.
    A long usb cord. Just in case someone brings an ipod or mp3 player in your car you can hook it up to your pc and go from there.
    A zip ties. Lots of those so you can bundle your wires together.
    I might have missed something.
    Oh how could I have forgotten this idea. Something that would allow you to hook your speakers in your car to the computer.
  5. 1slowlance
    Oh yeah, I remember now. My bad, yo. Lol.
    wouldnt an iTouch be way inexpensive?!?!?
  7. Jogenmaru
    With that thought, there would be a fitment issue in the newer lancers.
  8. 1slowlance
    You mean an iPad?
  9. blackeyed
    Good suggestion on liquid cooling...
    The only problem I see is that I don't want to loose my CD changer, hands-free and so on, so I want to build it additionally and connect it via AUX, not sure about the sound quality though. I have some dream of having sliding touchscreen built in like Volvo and Audi has but probably prices are out of my range. I have some idea but haven't seen any examples of it yet... there is so huge space in front that could be used well, :) only I don't know what is under the plastic.. is there any possibility to insert TV screen there...
  10. shieldwolf342
    Hey Ya its me currently doing this and a write up will here done over the weekend
    the cost of this depends really on what your looking for. My project is looking to run about 600ish
    but again it depends on what your looking for.
    LOOK HERE
    http://lancertuners.com/fuerza/showthread.php?t=8198&p=103319
  11. blackeyed
    Perfect, this is what I am looking for. I was also thinking of Lilliput touchscreen.
    I have the 2008 Lancer but I guess principle is the same. I only want to have it far more away (above clock in your case, not instead of radio)
    But thanks for sharing! Keep posted for any updates!
  12. shieldwolf342
    the issue putting it any higher is it technically blocks your view as a driver "officially" that why I chose where I did. But look at the the MIMO itouch screen I mention its about 140ish and is around the same size and is USB power touchscreen.
  13. Blakd
    Blakd Member
    I have thought about this quite a bit. If you cut out right above the glove box you can install a laptop with or without a screen. Put a keyboard that will slide out when the glove box is open. Then you can mount the monitor somewhere like where the passenger side airbag is and have it so you can lift it. Then run the obd II cable under the dash to the usb port on the laptop. This will allow you to have a stealth pc to tune your car with. You might also be able to put in a touch screen and use the rca's to connect to the laptop.
    Just my thoughts on what could be done. the most costly part would be the fab you would have to do on the dash, depending on what kind of laptop you use.
  14. bras_33
    also...WORD
  15. SPAMMER
    [lancer2quick]
  16. stevebucknor1
    stevebucknor1 Member
    I have thought about this quite a bit. If you cut out right above the glove box you can install a laptop with or without a screen. Put a keyboard that will slide out when the glove box is open. Then you can mount the monitor somewhere like where the passenger side airbag is and have it so you can lift it. It is really amazing and outstanding.
  17. UsedCarFleet
    UsedCarFleet New Member
    I already installed the car pc in my Indian Lancer GLXi 2000 model.
    I bought BYByte double din enclosure with liliput lcd monitor.
    And the Mini -ITX motherboard from intel.
    I ordered the PSU(with automatic shutdown controller) from china
    I already ran this setup for an year in Nissan Latio in Singapore and after returning to India in lancer. the system is in boot.
    You can check for more info here http://forums.usedcarfleet.com/yaf_...ncer-GLXi-Car-PC-Project-With-Navigation.aspx
  18. Jamesprigh
    Jamesprigh Well-Known Member
    https://odommobangladesh.org.bd/vodl/map.php
    http://freenutriflair.com/vika
    vevguliinsulancea324
    game plants vs zombies 2 download full version pc free , http://newsfrom690inpharakoq0.blogspot.com/2022/01/computers-themes-download-windows-7.html , download psp di pc free , windows 2003 delete downloaded updates free , https://sites.google.com/view/4m0qig2qj7hm2/c39wr3senz8zh1sd7u , download cygwin 64 bit windows free ,
    download wat remover tool for windows 7 ultimate free , http://newsfrom08orriadetsuk8.blogspot.com/2022/01/download-jogo-bow-and-arrow-windows-7.html , teracopy full download for windows 7 free , winsetupfromusb windows 7 download rar free , , creative pc cam software download free ,
    spss version 22 download for windows 8 free , , gta v pc game download link free , mu online download pc free , http://newsfrom9palfilakakv.blogspot.com/2022/01/sony-vegas-pro-9-download-free-full.html , download gps navigation software for windows 8 free ,
    windows 7 genuine download free , http://newsfrominpropstinfu4y.blogspot.com/2022/01/james-cameron-avatar-game-pc-save-file.html , download game ps2 winning eleven 10 free , download dau truong thu 4 cho pc free , https://sites.google.com/view/4jqzhniqsnkmq8bcvgcle78z2o/fczh703ccv , dazzle digital video creator 80 software download for windows 7 free ,
    download fifa 10 full version for windows 7 free , https://sites.google.com/view/gw54lskftkbd10vw/575gtfy30e , download jocuri gratis pc torent free , sniper elite v2 patch download pc free , http://newsfrom524riacetazoz6.blogspot.com/2022/01/city-of-heroes-pc-game-download.html , download stealth cctv pro for pc free ,
    download miscrits of volcano island game for pc free , http://newsfromplacativba9g.blogspot.com/2022/01/diabolik-lovers-pc-game-download.html , download windows event viewer plus free , download video broken wings alter bridge free , https://sites.google.com/view/am2hm4f78zuadlql7koc0e909nr4/al7n5l3lj7dm41 , subway surfers beijing download for pc free ,
    945 motherboard vga drivers download for windows 7 free
    new bollywood video songs download high quality for pc free
    download hypersonic 2 for windows 7 32bit free
    cara download di appstore lewat pc free
    http://bestfreefiles.org/map247.php
    http://firstaboutdowbload.org/map61.php
    download skin winamp modern free
    adobe acrobat 9 professional download for windows 7 free
    mozilla firefox download windows 7 32 bit free
    wintrack version 11 3d vollversion download free
    gta vice city ultimate trainer download for pc full version game free
    text edit download pc free
    865 motherboard vga driver for windows 7 download free
    cisco anyconnect vpn client download for windows 7 32 bit free
    fallout 3 pc dlc download free
    download combofix for windows 8 free
    gmail hangout download for windows 7 free
    https://bit.ly/3zWcQ8Y , the best download games for pc free , https://bit.ly/3qKVsRE , cupcake update.zip download free ,https://bit.ly/3qouW0s , xbox 360 minecraft tutorial world download for pc free ,
    https://bit.ly/3qreJHz , nba 2k13 download pc no survey free , https://bit.ly/3qMsIbd , jardinains 2 full version download for windows 7 free ,https://bit.ly/3tJXyU3 , photoshop download full version windows 7 crack free ,
    https://bit.ly/33pPmgC , download realtek high definition sound driver for windows 7 free , https://bit.ly/3I5DHT1 , download internet booster for windows 8.1 free ,https://bit.ly/3fHj9UD , download photos app windows 7 free ,
    https://bit.ly/3foBe9Z , download b612 selfie for pc free , https://bit.ly/3nGT64A , windows 7 pro oa download toshiba free ,https://bit.ly/33BNGjS , download yu-gi-oh forbidden memories + emulador para pc free ,
    https://bit.ly/33VMd8b , download battle vs chess pc full version free , https://bit.ly/3Ah3YuM , online download transformers games for pc free ,https://bit.ly/3noUY1u , symmetricom windiscovery download free ,
    windows office 2007 portable download free
    power rangers spd download for pc free
    winx jogos download free
    download google chrome beta 2013 for windows 7 free
    windows 8.1 download full version with crack free
    download subversion 1.8 windows free
    http://bestfreefiles.org/map197.php
    http://bestfreefiles.org/map167.php
    autocad 2010 download windows 7 64 bit free
    download game road rash jailbreak for pc free
    diablo 3 download completo pc iso free
    test drive unlimited 2 pc download utorrent free
    https://mtsn2kotakediri.sch.id/tvor/map.php
    https://soulfedphilly.com/mili
    http://228.how-tonow.fun/
    download dvd maker software for windows 7 free
    https://how-tonow.fun/map.php
  19. BristDof
    BristDof Well-Known Member
    windows 7 desktop icons missing free download
    https://394.xbestfiles.pro/
    https://386.xbestfiles.pro/
    https://31.atsluvefiles.in.net/
    https://349.atsluvefiles.fr/
    http://1052.downloadfirstyou.com/
    http://223.how-tonow.fun/
    adobe illustrator cc gradient mesh tutorial free download , best image viewer windows 10 free download free download , windows 7 sp2 standalone download free , windows 7 home premium 64 bit free download trial version free ,
    adobe premiere pro cc 2018 indir free download , bartender 3 celebs mix free download , windows web server 2008 r2 eol free download , windows 10 enterprise ltsb gaming free download ,
    https://aboutthreefiles.org/map49.php
    http://firstaboutdowbload.org/map56.php
    filezilla server download for windows xp free , windows 10 mobile plans task free download , pixelmator for windows 7 free download free , sketchup pro 2018 v18 + plugins pack free download ,
    microsoft visual studio 2010 ultimate setup download free download , driver talent download for windows 10 free , microsoft sql server 2008 r2 enterprise edition price free download , activate microsoft office 2013 professional plus offline free download ,
    download sony vegas pro 13 crack 64 bit free download , install microsoft project 2016 with office 365 free download , windows 10 dvd player driver free download , download vmware horizon client for 64-bit windows 10 free ,
    https://bit.ly/3tu6rRe
    https://bit.ly/3Agi27O
    https://bit.ly/3fJdtJT
    https://bit.ly/3nswYL9
    https://bit.ly/3qsPyoa
    https://bit.ly/34U2jjv , microsoft office 2016 not opening files free download , https://bit.ly/3nmvyld , windows 7 home basic 64 bit ram limit free download , https://bit.ly/31WZZXM , reset windows 8.1 pro settings free download ,
    https://bit.ly/3nI4WLK , windows 8.1 wifi driver 32 bit free download , https://bit.ly/3fnSUCG , windows 10 wifi not working after reset free download , https://bit.ly/3I2X3YX , download scarica microsoft office 2010 professional gratis eazel free download ,
    https://aboutthreefiles.org/map66.php
    http://bestfreefiles.org/map196.php
    https://bit.ly/3tQQ5Tb , pixelmator for ios review free download , https://bit.ly/3nGkQX2 , windows 7 iso file download without product key free download , https://bit.ly/3Kv8eeP , mastercam 2018 mill manual free download ,
    https://bit.ly/3KcMWmc , sony vegas pro 12 como editar videos free download , https://bit.ly/3FviwI8 , vmware workstation 10 para windows 7 32 bits free download , https://bit.ly/3rATpiu , adobe illustrator cc 2018 pathfinder free download ,
    https://bit.ly/3Fopwqg , adobe acrobat pro dc change highlight color free download , https://bit.ly/321Bx7E , gpedit.msc not working windows 10 home free download , https://bit.ly/3nIJ96s , sony sound forge audio studio 10 keygen free download free download ,
    adobe photoshop cc 2014 dds plugin free download
    business card composer 5 for mac free download
    windows 10 pro key code free free download
    windows 10 pro 2018 activation free download
    windows 7 home premium wikipedia free download
    http://bestfreefiles.org/map128.php
    http://allthewaydownload.com/map31.php
    disable windows 8.1 defender free download
    camtasia studio 8 vs sony vegas pro 12 free download , windows 7 intel 7th generation workaround free download , crack sony vegas pro 13 download free download , microsoft office professional 2010 price free download ,
    cd key microsoft excel 2016 free download , xbox one driver controller windows 7 free download , windows 10 factory reset stuck at 99 free download , free download adobe indesign cc 2014 free download ,
    design expert tutorial pdf free download , adobe photoshop cc 2017 transparent background free download , adobe photoshop cc pdf tutorial free download , logic pro x unexpectedly quit while trying to use the audio unit free download ,
    windows 7 professional iso free download 32 bit free download , windows 7 ultimate product key 32 bit 2018 free download free download , windows 10 home auf pro upgrade geht nicht free download , windows 10 disco duro al 100 por ciento free download ,
    bluetooth peripheral device driver windows 7 download free , microsoft office 2016 home & business - windows free download , keygen microsoft powerpoint 2013 free download , windows 7 pro crack key free download ,
    https://bit.ly/3I22nM5
    https://bit.ly/34JKp2x
    https://bit.ly/3KaTHFb
    https://bit.ly/3flnyfP
    https://bit.ly/3nM3yaR
    https://bit.ly/3AiuvYD , adobe indesign cs6 support free download , https://bit.ly/3nsyWLg , 3 point linkage bale feeder free download , https://bit.ly/3GrWoQd , windows 10 profile picture size free download ,
    https://aboutthreefiles.org/map90.php
    http://bestfreefiles.org/map266.php
    https://bit.ly/3zXtp4s , best free drum plugins for logic pro x free download , https://bit.ly/3Ftf29a , no me funciona el sony vegas pro 11 free download , https://bit.ly/3I4dHaE , windows 8.1 login password reset free download ,
    https://bit.ly/338lLZf , free download microsoft word 2010 for windows 8 64 bit free download , https://bit.ly/3qrSSzP , download ms word 2016 windows 10 free download , https://bit.ly/3GrmDGP , windows 10 new features update 2018 free download ,
    https://bit.ly/3rA46lk , total overdose free download full version for pc windows 7 free , https://bit.ly/3ttbnFW , windows 8.1 pro serial key 2019 free download , https://bit.ly/3AilEpW , adobe photoshop cc 2014 installer download free download ,
    https://bit.ly/3nJOMBB , windows 10 home iso download google drive free download , https://bit.ly/3Gv9yvT , adobe premiere pro cc 2019 rotate video free download , https://bit.ly/33jFipy , army enterprise email windows 10 free download ,
    https://how6youtoknowc.org/map.php
    https://howytooutoknowcgfdf.org/map.php
    https://howytooutoknowb.fun/map.php
    https://howyoutoknowacxv.online/map.php
    https://howyoutoknowa.online/map.php
  20. BristDof
    https://365.atsluvefiles.fr/
    http://236.downloadfirstyou.com/
    http://2078.downloadfirstyou.com/
    microsoft office word 2016 portable download free download , simtower download windows 10 free , windows server 2016 standard jdk free download , windows 10 pro 64 bit iso direct download free download ,
    bios windows 10 asus free download , windows 10 8gb ram 4gb usable free download , windows 7 ultimate or professional for gaming free download , autodesk revit architecture 2016 serial number and product key free download ,
    http://bestfreefiles.org/map60.php
    http://firstwaydownload.com/map15.php
    email microsoft office outlook 2007 free download , adobe premiere pro cc minimum system requirements free download , what does running windows 10 in s mode mean free download , windows 8.1 wpa2 enterprise free download ,
    microsoft excel 2013 and 2016 free download , download edge for windows 8.1 free , como descargar adobe fireworks cs6 free download , microsoft project standard 2016 price malaysia free download ,
    https://bit.ly/3304Rfg , autodesk inventor 2017 what's new pdf free download , https://bit.ly/3J1lVkh , windows 10 wifi password command line free download , https://bit.ly/3Go1n3B , windows 7 usb dvd download tool 2019 free download ,
    https://bit.ly/3AWQ7Kx , logo windows 10 download free download , https://bit.ly/3HrtGja , pdf expert google drive sync free download , https://bit.ly/3onUysX , capture one pro 12 vs lightroom classic free download ,
    windows 7 bootable tool usb free download , adobe acrobat pro dc edit pdf free download free download , microsoft games for windows 8 free download free , windows 7 domain join wizard free download ,
    autodesk autocad lt with cals tools 2019 free download , windows 10 xbox app we can't sign you in right now free download , microsoft office professional 2016 serial key 2019 free download , download adobe dreamweaver cs6 google drive free download ,
    https://116.atsluvefiles.fr/
    microsoft word 2013 pdf tutorial free download , windows 10 usb-dvd download tool free , windows 7 recovery forgot password free download , autodesk inventor professional 2009 download free download ,
    windows 10 home not showing network computers free download , microsoft office professional plus 2016 64 bit free download free download , windows 7 professional drivers free download , windows 7 folder size download free download ,
    https://597.xbestfiles.pro/
    https://bit.ly/3rAoSBf , windows 7 enterprise iso download free free download , https://bit.ly/3GOoghS , windows vista home premium service pack 3 32 bit free download , https://bit.ly/3tJR47q , vmware fusion 10 pro requirements free download ,
    https://bit.ly/3tj5ivY , windows 10 release date 1909 free download , https://bit.ly/3Ak2D6C , windows 7 32 bit iso vm free download , https://bit.ly/33z3jcl , windows 7 64 bit preactivated iso google drive free download ,
    https://bit.ly/3qZKfvm , download setup adobe premiere pro cs6 free download , https://bit.ly/3qvoIeY , pixelmator svg export free download , https://bit.ly/3HTIFlM , windows 7 pre activated free download free ,
    download microsoft windows media player 9.0 free
    microsoft publisher 2013 apk free download
    download sp2 windows 2000 free , micrografx windows draw 6 free download free , microsoft office professional 2013 crack free download free download , conexant smartaudio hd download windows 10 free ,
    https://663.anbrefiles.ca/
    windows 7 yellow triangle no internet access free download , cara update windows 8.1 pro manual free download , como formatear windows 7 professional sin cd free download , windows xp professional end of life free download ,
    windows 7 home premium vs ultimate gaming free download , download microsoft word 2013 free 64 bit free download , kmspico windows server 2012 standard evaluation free download , microsoft office 2016 not opening windows 10 free download ,
    http://newsfrom5tempgresdiaka5d.blogspot.com/2022/02/adobe-flash-cs4-professional-version.html , vmware workstation pro 14 free download free download , http://newsfrom6hydlinihixc.blogspot.com/2022/02/hunter-games-for-pc-download-free7-free.html , autodesk autocad lt 2018 for mac free download , http://newsfrom04talcernaza3y.blogspot.com/2022/02/acdsee-ultimate-10-download-free.html , windows 7 32 bit games compatibility free download ,
    http://newsfromdiugadiure60.blogspot.com/2021/12/internet-explorer-for-windows-xp-free.html , coreldraw graphics suite x7 descargar gratis free download , http://newsfrom4comcallubofo.blogspot.com/2021/12/free-bios-download-windows-xp.html , sony vegas pro free download 13 free download , http://newsfromcanrucabita.blogspot.com/2021/12/road-rush-free-download-for-windows-7.html , 64 bit windows 7 sp1 free download ,
    windows 8.1 keyboard driver update free download , free download office 2003 for windows 8 free , descargar microsoft office 2008 para mac free download , microsoft project 2013 print gantt chart only free download ,
