weird smell? burning smell
Discussion in '8G Lancer - General Information' started by chicagolancer, Sep 18, 2008.
  1. chicagolancer
    chicagolancer Member
    has anyone had like a burning smell from the engine when you drive it hard? i still have that smell, and i had it since july 07. idk if it's suppose to smell like that, but guys around me said its weird that it does that.
  2. lancered
    lancered Well-Known Member
    do you have a SPIRITED drving style?smells bad???sounds to me like your clutch is failing.take it to the shop/dealer.
  3. chicagolancer
    even though its a cvt?
  4. pimpinfern
    pimpinfern Well-Known Member
    stop eating bean burritos
  5. lancered
    well in that case you shouldve said it was a cvt.the belt on your torque converter sounds like its slipping or even rubbing,take it to the dealer.
  6. EngRWW33
    EngRWW33 Well-Known Member
    :D
    +1 on taking it to tthe dealer
  7. jazket
    jazket Well-Known Member
    ur pushing the car way too much.. I've done the same and yes its some horrid burnin smell.. nothing to do w anything failing on ur car... though I wouldnt take any chances if u find it smelling when its not supposed to.
    ride ur car too hard, and of course iut'll smell like burning. Get a Ralliart or an Evo if u want to run recklessly. our cars are slow as fvck.
  8. chicagolancer
    i agree with that, our cars r slow as hell...its not as fast as i thought it would be...might be getting the ralliart in couple weeks
  9. sordid
    sordid Well-Known Member
    No smell coming from mine, and I've done a good number of spirited driving stints. I love the way it handles when you grab it by the scruff of the neck.
    As below, mine's a M/T so..
    I thought I smelled clutch after some interesting driving, but it just turned out to be the puffwheat factory :O
  10. aratkrision
    aratkrision Active Member
    Your not alone, i have excatly the same problem, some kind of strange like burning smell, i spoke to the dealer and they told me that they were going to check it in.
    i tought that it was a plastic bag, or maybe the HID overcharging the wires or something, i tought that the exahust was broken but everything was fine even the brakes.
    after trying everything i found a solution, maybe it will work for u, try this, open the a/c vent so you can get the air from the outside try to keep it open for a couple of hours, after that close it and try to hit it hard again, the smell is gone, you can smell it sometimes thought, im about to send the car to the dealer to check that problem but if you figure out what its let me know n_n
    P.S english is not my firt language so i apologize if my english "reads" weird XD
  11. kingklay
    kingklay Well-Known Member
    Did you find a solution?? About 2 weeks after lowering my car im getting a strange burning smell from the front end. I cant see it having anything to do with the lowering since i have no rubbing at all, but it is odd timing. Shes going in to be checked this monday.
  12. kingklay
    Well i jacked my car up at work today to have a look and i found some plastic melted to my exhaust pipe.. PHEWWWWWWWW!!
  13. TheDude
    TheDude Well-Known Member
    I had a somewhat similar smell, and it turned out to be a plastic bag on my Cat. Look under your car and see if it looks a lil rusted to a weird color. Most peopel find out its only a bag.
