Is the the PAC-SWI-X the unit i need to get my bluetooth working with an aftermarket head unit? I know it will get the steering wheel controls working but im less conserned with them then the bluetooth.
No, that just allows you to maintain the stereo steering wheel controls. No the bluetooth. If you change the headunit, you lose the stock bluetooth feature.
Most mid to high end aftermarket HUs are bluetooth compatable, you just gotta buy their bluetooth package/kit and install it.
if you change to an aftermarket HU you will NOT lose the bluetooth feature, you will use the bluetooth capablity of seeing the menu on your headunit but your bluetooth will still function.
BS. The bluetooth is powered off the stock headunit. You change the headunit, there is no place for the bluetooth harness to plug into.
How much was that headunit with the built in bluetooth and can you still use the steering wheel controls? What other audio stuff have you done?
If you change to an after market HU you will NOT lose the bluetooth feature, you will use the bluetooth capablity of seeing the menu on your head unit but your blue tooth will still function.This is the main thing to remember.
