navigation?
Discussion in '8G Lancer - Customization' started by LJ-GTS, Oct 8, 2008.
  1. LJ-GTS
    LJ-GTS Member
    can somone tell me how to convert my regular radio into the touch screen that comes with the navigation package? and where can i get all the parts? thanks
  2. RALLIART
    there is several ways. You want the oem navigation i presume?
    ok. IF you want to look as close as possible or even exaclty like the one that comes from dealer. You have to get the dash kit from mitsubishiparts.net it will run you a pretty penny, some 300.00 for a dash kit.
    It comes with the Double din opening with vents, navigation antenna, wiring for the OEM unit.
    Then IF you want to get the OEM navigation unit it will run you from 1000.00 to 2000.00 dollars! above is IF you wanna have the unit that comes from dealer.
    Now there are cheaper dash kits out there, metra makes one and so is skoche. No more than 50 or 60.00 for the dash kit.
    Getting a 7 inch touch screen other than OEM will start from 1200.00
    crutchfield.com
  3. LJ-GTS
    LJ-GTS Member
    thanks alot
