HID
Discussion in 'AutoMoGlow.com' started by Analog, Jul 16, 2007.
  1. Analog
    Analog Member
    Does anyone know what type of HID to get if you want to
    A) change the stock headlams,
    B) Foglams
    any ideas? Im up for suggestions/ whats the best?
  2. rav
    rav New Member
    bump ^^
    Same question. What type of HID bulbs is needed for the gts lancer08 and does anyone know any good brands for HID'ing the foglights?
  3. RALLIART
    please post in the appriopriate section of the forums!!
  4. Automoglow
  5. Sp4rt4n
    Sp4rt4n Well-Known Member
    just be aware there is no good workaround for defeating the daytime running lights yet.
  6. Sp4rt4n
  7. LancerGTS
    you and me both brotha
  8. Trainwrcked
    Trainwrcked Member
    Just something I was thinking about on the way home. There is a connector right behind each headlight. When you unplug it, the lights are off (all of them). In theory, if you could isolate the prong that is the DRL, wouldn't it make sense that the ECU would think it's connected when really that prong wouldn't be touching the reciprical prong. I know it sounds like a hack, but like I said, it's just something I was thinking on the way home. I don't have the tools to check voltage or anything like that, but maybe someone else could?
  9. jRox
    ^^someone try it out :D
  10. mvattamatt
    mvattamatt Active Member
    i just had my HID installed but after 1 month, the right lite will be on and after 15 mins it will go off. What seems to be the problem? Can you advise me please?
    thanks,
    marvin
  11. mvattamatt
  12. lancermike
    lancermike Well-Known Member
    you need a relay and you should be fine the guy who does my tints did mine but i dunno how no relay n they work perfect he did some drl bypass
  13. mvattamatt
    The guy that installed it placed a relay. First few weeks its ok but now it keeps turning off. The owner will replace my kit with a brand new one. If the problem persist, I don't know If i will just go back to stock lites. Hope its going to be ok.
    thanks bro
    marvin
  14. WillieetheOne
    well i tried the relay and the sane happened. removed it then just drove with the lights on, then it went random sometimes on some times off?? I guess it just the way they go it is really frustrating. My service dept wanted to try something bu at 80 bucks an hour and a minimum of three hours well i dont think so. Not when the HIDS cost me 140.00. Just didnt like the math.
  15. mvattamatt
    how did he bypass the URL?
  16. mvattamatt
    how he bypass it?
  17. Automoglow
    whats the most popular HID color temp you prefer?
