BRAKES Road/Race Motorsports - StopTech slotted rotors (front); ES/DE ($189) and GTS ($199) versions available Road/Race Motorsports - RRM Front Big Brake Kit; for DE/ES models only ($569) Road/Race Motorsports - RRM/Rotora 4-piston Front Big Brake Kit, Street ($1399) Road/Race Motorsports - RRM/Rotora 4-piston Front Big Brake Kit ($1899) Road/Race Motorsports - RRM/Rotora 4-piston Front Big Brake Kit, Track ($2199) Road/Race Motorsports - RRM/Rotora 2-piston Rear Big Brake Kit ($1599) Brake hoses Road/Race Motorsports - front, stainless steel braided ($89) Works - front & rear kit, in production Brake Pads See below***** Camber bolts Specialty Products Company - front (available at Road/Race Motorsports for $89) Coilovers Megan Racing Street Series Coilovers - now available (can be purchased at multiple automotive vendors, including Road/Race Motorsports) Limited Slip Differential (LSD) TRD and Quaife LSD units made for the Scion tC should fit the MT models. "The 08 lancer uses the same Aisin 5 speed as in the Scion TC, so you can use the TRD and Quaiffe diffs made for that car. I can't remember which one the Road Race car has, but I know its one of the above." Springs see below**** Suspension braces Megan Racing - front strut brace in production Road/Race Motorsports - front strut brace ($149) Road/Race Motorsports - rear strut brace ($99) Road/Race Motorsports - lower truss bar ($139) Road/Race Motorsports - lower tiebar set ($99) Road/Race Motorsports - Combo, all four of these ($436, saves $50) Swaybars Road/Race Motorsports - G.R.I.P. swaybar (manufactured by Progress), 22mm ($179) Works - Adjustable Sway Bar (Rear), 22mm, 2-way adjustable ($199) Ptuning.com Progress: 22mm adjustable sway bar Part number: PT62.1431 Price: 157.25
BRAKE PADS FRONT AXXIS/PBR MTS077483 - Ultimates MTS070551 - Deluxe MTS070554 - Metal Masters EBC Brakes D866 - Ultimax, OE grade DP21614 - Greenstuff DP31614C - Redstuff DP41614R - Yellowstuff, race pads Hawk Performance HB435F.622 - HPS, street HB435Y.622 - LTS, intended for trucks, but it will fit Porterfield AP866 - available in R4, R4-E, R4-S and R4-1 (R4-S pads available here; link says GTS, but will fit ES/DE as well) Raybestos ST-43 race pads (available here; link says GTS, but will fit ES/DE as well) Road/Race Motorsports Brake pads (brand/model unknown) - Direct link ------------------------------- REAR (according to FMSI number, these will only fit ES models; see otter's post below) EBC Brakes D1037 - Ultimax, OE grade DP21563 - Greenstuff DP31563C - Redstuff DP41563R - Yellowstuff Hawk Performance HB457N.605 - HP Plus, street HB457F.605 - HPS, street HB457Z.605 - Performance ceramic, street HB457E.605 - Blue 9012, race HB457S.605 - HT10, race
SPRINGS Eibach - Pro Kit & Sportline Kit Price varies by vendor Pro Kit - 1.2 Inch Front, 0.8 Inch Rear Sportline Kit (In Development) - 1.7 Inch Front : 1.2 Inch Rear Note - spring rates unknown H&R - Sport Springs Retail is $329, actual price varies by vendor Drop 1.4" front, 1.3" rear Note - spring rates unknown Road/Race Motorsports - G.R.I.P. springs Version 2 $179 Drop: 1.5" front and 1.4" rear Spring rate - 175 front & rear. Note - bumpstops need to be cut during install Tanabe Racing - NF210 (Normal Feel) springs Retail is $260, actual price varies by vendor No drop or spring rate information available. Works - Ride springs $299 Drop: 28mm front & rear Note - spring rates unknown PROGRESS Available at ptuning.com Front -1.5 Rear -1.5 Part number: PT40.1431 Price: 174.25 Free shipping
hey, jw, has anyone ordered one of the brake kit from RRM? i dont know much about Rotora, is this a good brake company? -might be a noob question
Limited Slip Differential (LSD) TRD and Quaife LSD units made for the Scion tC should fit the MT models. "The 08 lancer uses the same Aisin 5 speed as in the Scion TC, so you can use the TRD and Quaiffe diffs made for that car. I can't remember which one the Road Race car has, but I know its one of the above." --- Can this be confirmed ???
