Tools needed:
10mm Socket
Phillips Head Screw Driver
Flat Head Screw Driver
Some Sort of Cloth
First step is to figure out where your taillights are. After you have done this you already won half the battle.
Second you will have to open the trunk
or this
Third take your phillips head screw driver and unscrew these 2 screws. You will need to take your flat head screw driver and cloth and prey it out
Fourth remove the bulbs and place them in the new light, and re-install.
Fith its time to start on the other light assembly. For this you will need to remove the trunk liner. You will need to take your flat head and pop these out.
Sixth take your 10mm socket and remove these 2 bolts.
[url=http://g.imageshack.us/img338/dscf1413lp7.jpg/1/][IMG]
Seventh replace with new taillight
Now do the same for the other side
Let me tell you these are freckin sweet. They make the car look so much better.
Thank you and have a nice day
